跳转到主内容
Dell XPS 13 9310 Lower Case Replacement
你所需要的
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: 步骤 3 中的图像 1,2 Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: 步骤 3 中的图像 2,2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Lower Case Replacement: 步骤 5 中的图像 1,3 Dell XPS 13 9310 Lower Case Replacement: 步骤 5 中的图像 2,3 Dell XPS 13 9310 Lower Case Replacement: 步骤 5 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
59,654 声望
创作了430篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,893篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 40
过去 30 天: 122
总计 1,499
