跳转到主内容
Dell XPS 13 9305 SSD Replacement
你所需要的
  1. Dell XPS 13 9305 SSD Replacement, Remove the back screws: 步骤 1 中的图像 1,2 Dell XPS 13 9305 SSD Replacement, Remove the back screws: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
  2. Dell XPS 13 9305 SSD Replacement, Release the clips: 步骤 2 中的图像 1,2 Dell XPS 13 9305 SSD Replacement, Release the clips: 步骤 2 中的图像 2,2
    • At each corner, insert an opening pick between the back cover and the device body.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Dell XPS 13 9305 SSD Replacement, Remove the back cover: 步骤 3 中的图像 1,3 Dell XPS 13 9305 SSD Replacement, Remove the back cover: 步骤 3 中的图像 2,3 Dell XPS 13 9305 SSD Replacement, Remove the back cover: 步骤 3 中的图像 3,3
    • The edges of the cover are very sharp. Use caution when handling this panel.
    • Lift the front edge of the cover away from you.
    • Some clips may release during this step. If the cover is stuck, move it side to side to help release additional clips.
    • Remove the back cover from the laptop.
  4. Dell XPS 13 9305 SSD Replacement, Disconnect the battery cable: 步骤 4 中的图像 1,3 Dell XPS 13 9305 SSD Replacement, Disconnect the battery cable: 步骤 4 中的图像 2,3 Dell XPS 13 9305 SSD Replacement, Disconnect the battery cable: 步骤 4 中的图像 3,3
    • Push the battery connector out of its socket using the pointed end of a spudger.
    • Push the small tabs on the side of the connector to avoid damaging the cables.
  5. Dell XPS 13 9305 SSD Replacement, Remove the screw from the SSD cover: 步骤 5 中的图像 1,2 Dell XPS 13 9305 SSD Replacement, Remove the screw from the SSD cover: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the 3.7 mm-long screw from the SSD cover.
    • This cover won't be used if an 80 mm-long full-size SSD is installed.
  6. Dell XPS 13 9305 SSD Replacement, Pull the SSD cover off: 步骤 6 中的图像 1,3 Dell XPS 13 9305 SSD Replacement, Pull the SSD cover off: 步骤 6 中的图像 2,3 Dell XPS 13 9305 SSD Replacement, Pull the SSD cover off: 步骤 6 中的图像 3,3
    • Pull the cover off and away from the silver retaining peg.
    • During reassembly, don't install this cover if you're upgrading to a full-size SSD. The cover is needed only for 30 mm-long (M.2 2230) SSDs.
  7. Dell XPS 13 9305 SSD Replacement, Remove the SSD by hand: 步骤 7 中的图像 1,3 Dell XPS 13 9305 SSD Replacement, Remove the SSD by hand: 步骤 7 中的图像 2,3 Dell XPS 13 9305 SSD Replacement, Remove the SSD by hand: 步骤 7 中的图像 3,3
    • Grab the SSD by the corners. Be gentle to not pull up on the SSD.
    • Pull it straight out from the socket. If it feels stuck, wiggle it side to side.
  8. Dell XPS 13 9305 SSD Replacement, Reassembly notes: 步骤 8 中的图像 1,1
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
2等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
95,850 声望
创作了466篇指南
2指南评论
I don't know whether anyone had the same experience, but the SSD keeps disconnecting sometimes. Does anyone have any idea whether it is possible to put something inside so that it keeps the SSD seated properly in the slot?
Aleš Sršeň - 回复
If it's a long SSD, did you remove the shield?
Franck Quintana -
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 53
过去 30 天: 142
总计 3,772
