跳转到主内容
Dell XPS 13 9300 SSD Replacement
你所需要的
  1. Dell XPS 13 9300 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Dell XPS 13 9300 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9300 SSD Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Dell XPS 13 9300 SSD Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9300 SSD Replacement, Release the case's front clips: 步骤 3 中的图像 1,2 Dell XPS 13 9300 SSD Replacement, Release the case's front clips: 步骤 3 中的图像 2,2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9300 SSD Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 Dell XPS 13 9300 SSD Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 Dell XPS 13 9300 SSD Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9300 SSD Replacement: 步骤 5 中的图像 1,3 Dell XPS 13 9300 SSD Replacement: 步骤 5 中的图像 2,3 Dell XPS 13 9300 SSD Replacement: 步骤 5 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. Dell XPS 13 9300 SSD Replacement, Disconnect the battery: 步骤 6 中的图像 1,3 Dell XPS 13 9300 SSD Replacement, Disconnect the battery: 步骤 6 中的图像 2,3 Dell XPS 13 9300 SSD Replacement, Disconnect the battery: 步骤 6 中的图像 3,3
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
    • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
    • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
  7. Dell XPS 13 9300 SSD Replacement, Loosen the antenna wire: 步骤 7 中的图像 1,3 Dell XPS 13 9300 SSD Replacement, Loosen the antenna wire: 步骤 7 中的图像 2,3 Dell XPS 13 9300 SSD Replacement, Loosen the antenna wire: 步骤 7 中的图像 3,3
    • Use the flat end of a spudger to pry up and loosen the antenna wire from the SSD cover.
    • Repeat this process along the entire edge of the SSD cover.
  8. Dell XPS 13 9300 SSD Replacement, Unfasten the SSD cover: 步骤 8 中的图像 1,2 Dell XPS 13 9300 SSD Replacement, Unfasten the SSD cover: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.6 mm screw securing the SSD cover
  9. Dell XPS 13 9300 SSD Replacement, Remove the SSD cover: 步骤 9 中的图像 1,3 Dell XPS 13 9300 SSD Replacement, Remove the SSD cover: 步骤 9 中的图像 2,3 Dell XPS 13 9300 SSD Replacement, Remove the SSD cover: 步骤 9 中的图像 3,3
    • Pull the SSD cover away from its fastener to remove it.
  10. Dell XPS 13 9300 SSD Replacement, Remove the SSD: 步骤 10 中的图像 1,3 Dell XPS 13 9300 SSD Replacement, Remove the SSD: 步骤 10 中的图像 2,3 Dell XPS 13 9300 SSD Replacement, Remove the SSD: 步骤 10 中的图像 3,3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
  11. Dell XPS 13 9300 SSD Replacement, Reassembly notes: 步骤 11 中的图像 1,1
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
Spencer Day
于09/14/22注册
155,036 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,779篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 58
总计 2,399
