跳转到主内容
Dell Vostro 5510 Motherboard Replacement
你所需要的
  1. Dell Vostro 5510 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Motherboard Replacement: 步骤 3 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement: 步骤 3 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Motherboard Replacement: 步骤 4 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement: 步骤 4 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Motherboard Replacement, Fan: 步骤 5 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement, Fan: 步骤 5 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement, Fan: 步骤 5 中的图像 3,3
    • Disconnect the fan cable from the system board.
  6. Dell Vostro 5510 Motherboard Replacement: 步骤 6 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement: 步骤 6 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the two (M2x3mm) screws from the fan using the screwdriver.
  7. Dell Vostro 5510 Motherboard Replacement: 步骤 7 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Lift the fan to remove it.
  8. Dell Vostro 5510 Motherboard Replacement, Wireless Card: 步骤 8 中的图像 1,1
    • Locate the wireless card.
  9. Dell Vostro 5510 Motherboard Replacement: 步骤 9 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the screw (M2x3mm) from the wireless card with the screwdriver.
    • Lift the card without removing it completely.
  10. Dell Vostro 5510 Motherboard Replacement: 步骤 10 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Disconnect the antenna cables from the wireless card.
  11. Dell Vostro 5510 Motherboard Replacement, SSD Card: 步骤 11 中的图像 1,1
    • Locate the SSD card.
  12. Dell Vostro 5510 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the screw (M2x3mm) with the screwdriver.
  13. Dell Vostro 5510 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Grab the elevated side of the card.
    • Remove the card from the card slot.
  14. Dell Vostro 5510 Motherboard Replacement, Motherboard: 步骤 14 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement, Motherboard: 步骤 14 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement, Motherboard: 步骤 14 中的图像 3,3
    • Loosen the four 2.9 mm screws from the heat pipe with the Phillips #0 screwdriver.
    • Remove the heat pipe with your fingers.
  15. Dell Vostro 5510 Motherboard Replacement: 步骤 15 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove the three 4.9 mm screws from the hinge on the left with the Phillips #0 screwdriver.
    • Lift the hinge up from the motherboard.
  16. Dell Vostro 5510 Motherboard Replacement: 步骤 16 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Remove the two 4.7 mm screws from the metal plate on the left of the motherboard with the Phillips #0 screwdriver.
    • Remove the metal plate with your fingers.
  17. Dell Vostro 5510 Motherboard Replacement: 步骤 17 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Remove the 3.7 mm screw from the flat plate at the top of the motherboard with the Phillips #0 screwdriver.
    • Remove the flat plate with your fingers.
  18. Dell Vostro 5510 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove the three 2.2 mm screws from the motherboard with a Phillips #0 screwdriver.
  19. Dell Vostro 5510 Motherboard Replacement: 步骤 19 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement: 步骤 19 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement: 步骤 19 中的图像 3,3
    • Detach the four connectors at the top of the motherboard with your fingers.
  20. Dell Vostro 5510 Motherboard Replacement: 步骤 20 中的图像 1,3 Dell Vostro 5510 Motherboard Replacement: 步骤 20 中的图像 2,3 Dell Vostro 5510 Motherboard Replacement: 步骤 20 中的图像 3,3
    • Disconnect the white plug from the top of the motherboard with your fingers.
  21. Dell Vostro 5510 Motherboard Replacement: 步骤 21 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 21 中的图像 2,2
    • Disconnect the thick cord from the bottom of the motherboard.
  22. Dell Vostro 5510 Motherboard Replacement: 步骤 22 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 22 中的图像 2,2
    • Disconnect the white plug from the bottom of the motherboard.
    • Remove the entire part the plug is attached to with your fingers.
  23. Dell Vostro 5510 Motherboard Replacement: 步骤 23 中的图像 1,2 Dell Vostro 5510 Motherboard Replacement: 步骤 23 中的图像 2,2
    • Disconnect the thick cord from the right of the motherboard with your fingers.
  24. Dell Vostro 5510 Motherboard Replacement: 步骤 24 中的图像 1,1
    • Lift the motherboard gently using your hands.
结论
NPUNT
于02/08/24注册
193 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 53
