跳转到主内容
Dell Vostro 1320 USB Port Replacement
你所需要的
  1. Dell Vostro 1320 USB Port Replacement, USB Port: 步骤 1 中的图像 1,1
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: 步骤 2 中的图像 1,1
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: 步骤 3 中的图像 1,3 Dell Vostro 1320 USB Port Replacement: 步骤 3 中的图像 2,3 Dell Vostro 1320 USB Port Replacement: 步骤 3 中的图像 3,3
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: 步骤 4 中的图像 1,1
  5. Dell Vostro 1320 USB Port Replacement: 步骤 5 中的图像 1,3 Dell Vostro 1320 USB Port Replacement: 步骤 5 中的图像 2,3 Dell Vostro 1320 USB Port Replacement: 步骤 5 中的图像 3,3
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: 步骤 6 中的图像 1,1
  7. Dell Vostro 1320 USB Port Replacement: 步骤 7 中的图像 1,2 Dell Vostro 1320 USB Port Replacement: 步骤 7 中的图像 2,2
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: 步骤 8 中的图像 1,1
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: 步骤 9 中的图像 1,2 Dell Vostro 1320 USB Port Replacement: 步骤 9 中的图像 2,2
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: 步骤 10 中的图像 1,3 Dell Vostro 1320 USB Port Replacement: 步骤 10 中的图像 2,3 Dell Vostro 1320 USB Port Replacement: 步骤 10 中的图像 3,3
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: 步骤 11 中的图像 1,1
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: 步骤 12 中的图像 1,1
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: 步骤 13 中的图像 1,2 Dell Vostro 1320 USB Port Replacement: 步骤 13 中的图像 2,2
    • Gently lift out the USB port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 647
