跳转到主内容
配件
没有特定配件。
  1. Turn the laptop over so that the bottom of it is exposed. The section of the computer that we need to access is the right panel. You need to start by using the J00 bit attachment to the Bit Driver to unscrew the screw
    • Turn the laptop over so that the bottom of it is exposed.
    • The section of the computer that we need to access is the right panel. You need to start by using the J00 bit attachment to the Bit Driver to unscrew the screw
  2. Use the flat Metal Spudger to open the plastic panel. If the panel does not open right away try placing the flat Metal Spudger to the adjacent or opposite side of the plastic panel. If the panel does not open right away try placing the flat Metal Spudger to the adjacent or opposite side of the plastic panel.
    • Use the flat Metal Spudger to open the plastic panel.
    • If the panel does not open right away try placing the flat Metal Spudger to the adjacent or opposite side of the plastic panel.
  3. Unplug the wire connecting the fan to the computer by pulling straight up on the connector.
    • Unplug the wire connecting the fan to the computer by pulling straight up on the connector.
  4. Remove the two black screws holding the fan down by using the phillips head screwdriver. Remove the two black screws holding the fan down by using the phillips head screwdriver.
    • Remove the two black screws holding the fan down by using the phillips head screwdriver.
  5. Gently pull the fan away from the side of the computer. Lift it out completely. At this point you can now blow all the dust out of your fan and the copper heatsink.
    • Gently pull the fan away from the side of the computer. Lift it out completely.
    • At this point you can now blow all the dust out of your fan and the copper heatsink.
结论
2等其他人完成本指南。
Christie Lloyd
于2015年08月26日注册
431 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 485
