跳转到主内容
Dell Venue 11 Pro USB Port Replacement
你所需要的
  1. Dell Venue 11 Pro USB Port Replacement, Battery: 步骤 1 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement, Battery: 步骤 1 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro USB Port Replacement: 步骤 2 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 2 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 2 中的图像 3,3
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro USB Port Replacement, Frame: 步骤 3 中的图像 1,2 Dell Venue 11 Pro USB Port Replacement, Frame: 步骤 3 中的图像 2,2
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro USB Port Replacement: 步骤 4 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 4 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 4 中的图像 3,3
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro USB Port Replacement: 步骤 5 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 5 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 5 中的图像 3,3
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro USB Port Replacement: 步骤 6 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 6 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 6 中的图像 3,3
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro USB Port Replacement: 步骤 7 中的图像 1,1
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro USB Port Replacement: 步骤 8 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 8 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 8 中的图像 3,3
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro USB Port Replacement: 步骤 9 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 9 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 9 中的图像 3,3
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
  10. Dell Venue 11 Pro USB Port Replacement, USB Port: 步骤 10 中的图像 1,1
    • Start by removing the top ZIF USB ribbon connector
    • If you are replacing the motherboard by itself, then skip steps 23, 24, and 25.
  11. Dell Venue 11 Pro USB Port Replacement: 步骤 11 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 11 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 11 中的图像 3,3
    • To remove the ribbon cable, move the black retainer upwards. Then pull the ribbon cable rearwards to remove it.
  12. Dell Venue 11 Pro USB Port Replacement: 步骤 12 中的图像 1,1
    • You must then remove the ribbon cable connected to the USB port located here.
  13. Dell Venue 11 Pro USB Port Replacement: 步骤 13 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 13 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 13 中的图像 3,3
    • Using a Philips #000 screwdriver remove the two 2.5 mm screws indicated.
  14. Dell Venue 11 Pro USB Port Replacement: 步骤 14 中的图像 1,3 Dell Venue 11 Pro USB Port Replacement: 步骤 14 中的图像 2,3 Dell Venue 11 Pro USB Port Replacement: 步骤 14 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers disconnect the connector from the circuit board
  15. Dell Venue 11 Pro USB Port Replacement: 步骤 15 中的图像 1,2 Dell Venue 11 Pro USB Port Replacement: 步骤 15 中的图像 2,2
    • After disconnecting all the pieces, remove the USB port circuit board with your fingers
结论
7等其他人完成本指南。
Tom Nguyen
于09/28/17注册
1,277 声望
创作了6篇指南
团队
USF Tampa, Team S3-G1, Nance Fall 2017 USF Tampa, Team S3-G1, Nance Fall 2017 的会员
USFT-NANCE-F17S3G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 2,845
