本指南有最近更改,您可查看未经巡查的最新版本。
简介
To successfully remove the LCD Screen display, one must first remove several components from within the device. Listed as prerequisites, components that require removal are the Battery, Frame, HDMI Port, Speakers, USB Port, and Motherboard. Once these prerequisites are met, the LCD Screen can easily be removed by following the corresponding steps.
你所需要的
Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
Identify the location of the HDMI Port, which will be in the left bottom part of the tablet.
Locate the right and left speakers to be replaced. For this guide, we will start with the left speaker, then the right speaker.
Next you must disconnect the black and white coaxial connector cables. We'll start with the black cable.
Use the tweezers again to grab hold of the black coaxial connector and pull upwards to disconnect.
Now we turn our attention to the backside webcam on the top portion of the shell.
5等其他人完成本指南。
