跳转到主内容
Dell Streak 7 Screen Replacement
你所需要的
  1. Dell Streak 7 Screen  Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Screen  Replacement: 步骤 2 中的图像 1,1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Screen  Replacement: 步骤 3 中的图像 1,1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Screen  Replacement: 步骤 4 中的图像 1,1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Screen  Replacement: 步骤 5 中的图像 1,2 Dell Streak 7 Screen  Replacement: 步骤 5 中的图像 2,2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Screen  Replacement: 步骤 6 中的图像 1,1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Screen  Replacement: 步骤 7 中的图像 1,2 Dell Streak 7 Screen  Replacement: 步骤 7 中的图像 2,2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Screen  Replacement, Screen: 步骤 8 中的图像 1,1
    • Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
  9. Dell Streak 7 Screen  Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, peel off the tape securing the screen to the metal cage around it.
  10. Dell Streak 7 Screen  Replacement: 步骤 10 中的图像 1,2 Dell Streak 7 Screen  Replacement: 步骤 10 中的图像 2,2
    • Pull out the ribbon cables through the opening in the metal cage.
    • Lift up the metal cage surrounding the screen by swinging the cage from one side.
  11. Dell Streak 7 Screen  Replacement: 步骤 11 中的图像 1,1
    • Remove the screen by lifting the screen from the front glass.
结论
2等其他人完成本指南。
Ali Benjelloun
于10/02/16注册
376 声望
创作了3篇指南
团队
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 481
