跳转到主内容
Dell Streak 7 Battery Replacement
你所需要的
  1. Dell Streak 7 Battery Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Battery Replacement: 步骤 3 中的图像 1,1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Battery Replacement: 步骤 4 中的图像 1,1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Battery Replacement: 步骤 5 中的图像 1,2 Dell Streak 7 Battery Replacement: 步骤 5 中的图像 2,2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Battery Replacement: 步骤 7 中的图像 1,2 Dell Streak 7 Battery Replacement: 步骤 7 中的图像 2,2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Battery Replacement, Headphone Jack: 步骤 8 中的图像 1,1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Battery Replacement: 步骤 9 中的图像 1,2 Dell Streak 7 Battery Replacement: 步骤 9 中的图像 2,2
    • Pull the headphone jack up, away from the case.
  10. Dell Streak 7 Battery Replacement, GSM Module: 步骤 10 中的图像 1,2 Dell Streak 7 Battery Replacement, GSM Module: 步骤 10 中的图像 2,2
    • With the spudger, disconnect the antenna cable located on the module.
  11. Dell Streak 7 Battery Replacement: 步骤 11 中的图像 1,2 Dell Streak 7 Battery Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the tape connected to the GSM module.
  12. Dell Streak 7 Battery Replacement: 步骤 12 中的图像 1,2 Dell Streak 7 Battery Replacement: 步骤 12 中的图像 2,2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  13. Dell Streak 7 Battery Replacement: 步骤 13 中的图像 1,1
    • Disconnect the GSM module by lifting the module up, out of the case.
  14. Dell Streak 7 Battery Replacement, Motherboard: 步骤 14 中的图像 1,3 Dell Streak 7 Battery Replacement, Motherboard: 步骤 14 中的图像 2,3 Dell Streak 7 Battery Replacement, Motherboard: 步骤 14 中的图像 3,3
    • Using the spudger, disconnect the front camera by lifting up on the connector.
  15. Dell Streak 7 Battery Replacement: 步骤 15 中的图像 1,1
    • Using the Torx screwdriver, remove the six 3mm screws .
  16. Dell Streak 7 Battery Replacement: 步骤 16 中的图像 1,2 Dell Streak 7 Battery Replacement: 步骤 16 中的图像 2,2
    • Lift up the metal cover.
  17. Dell Streak 7 Battery Replacement: 步骤 17 中的图像 1,1
    • Use the spudger to lift the vibration motor out of the case.
  18. Dell Streak 7 Battery Replacement: 步骤 18 中的图像 1,1
    • Pull out the motherboard and the battery.
  19. Dell Streak 7 Battery Replacement, Battery: 步骤 19 中的图像 1,2 Dell Streak 7 Battery Replacement, Battery: 步骤 19 中的图像 2,2
    • Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,204
