跳转到主内容
Dell Precision T7600 Thermal Paste Replacement for Overheating CPU
你所需要的
  1. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU, Thermal Paste: 步骤 1 中的图像 1,1
    • Turn off the computer and unplug the power cord.
  2. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 2 中的图像 1,1
    • Press and hold the power button for 30 seconds.
  3. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 3 中的图像 1,2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 3 中的图像 2,2
    • Open the case using the handle on the side.
    • Locate the CPUs.
    • The two black boxes are radiators, the CPUs are under these two black boxes.
  4. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 4 中的图像 1,3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 4 中的图像 2,3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 4 中的图像 3,3
    • Remove the four 18mm screws from each of the black radiators with a Phillips #0 screwdriver. (8 screws total)
  5. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 5 中的图像 1,3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 5 中的图像 2,3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 5 中的图像 3,3
    • You need take all eight 18mm TONG DIN912 screws. (Each radiator has four.)
    • Remove the radiator vertically.
  6. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 6 中的图像 1,2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 6 中的图像 2,2
  7. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 7 中的图像 1,2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 7 中的图像 2,2
    • Squeeze 1 ML of thermal paste onto the clean CPU.
    • Don't worry about spreading the thermal paste around, as the pressure from the radiator should spread the paste evenly. You can check out this nifty Thermal Paste Application Guide if you need any help.
  8. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 8 中的图像 1,2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 8 中的图像 2,2
    • Replace the radiator tower, applying even pressure as you make contact with the CPU.
    • Tighten the screws slowly in a cross pattern, making sure that one side doesn't have more pressure than the other.
  9. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 9 中的图像 1,3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 9 中的图像 2,3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 9 中的图像 3,3
    • Make sure the memory sticks are firmly affixed into the slots and the graphics card is connected.
    • The green check shows a good RAM connection and the X shows a bad one.
    • Close the case.
  10. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 10 中的图像 1,2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: 步骤 10 中的图像 2,2
    • Plug in the power supply.
    • The power light should come one. This is the self-checking state, do not touch anything. Wait until the light goes off, indicating that the self-checking state is finished.
    • If the light does not go off (after 5 mins), you need to repeat steps 6 and 7.
结论
另外一个人完成了本指南。
HaoqingKang
于09/19/21注册
213 声望
撰写一个指南
团队
York University, Team F-12, Woodhouse Fall 2021 York University, Team F-12, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG12
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 31
总计 1,040
