简介
Use this guide to replace a faulty motherboard in your Dell Precision M4700.
The motherboard is a sheet of plastic that holds all the circuitry to connect the various components of a computer system. A failing motherboard will often cause the entire computer to fail. These symptoms include the computer shutting down randomly and the blue screen of death error.
Before using this guide, be sure to review the troubleshooting page . Often times, it is unnecessary to replace the entire motherboard.
你所需要的
Slide the release latch to unlock the battery.
Flip and remove the battery from the computer.
Remove the four 3mm screws that secure the keyboard to the computer with a Phillips #00 screwdriver.
Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
Disconnect the keyboard-data cable from the system board by flipping up the locking tab of the ZIF connector and gently pulling out the cable.
Remove the keyboard.
Disconnect the antenna cables from the WLAN card.
Remove one 3mm screw from the WLAN card with a Phillips #00 screwdriver.
Pull the WLAN card out of its connection using two fingers on each side.
另外一个人完成了本指南。
