跳转到主内容
加入维修社区 - 创建账户
Dell Precision 7560 Touchpad Replacement
你所需要的
  1. Dell Precision 7560 Touchpad Replacement, Battery: 步骤 1 中的图像 1,3 Dell Precision 7560 Touchpad Replacement, Battery: 步骤 1 中的图像 2,3 Dell Precision 7560 Touchpad Replacement, Battery: 步骤 1 中的图像 3,3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Touchpad Replacement: 步骤 2 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 2 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 2 中的图像 3,3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Touchpad Replacement: 步骤 3 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 3 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 3 中的图像 3,3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Touchpad Replacement, Speaker: 步骤 4 中的图像 1,3 Dell Precision 7560 Touchpad Replacement, Speaker: 步骤 4 中的图像 2,3 Dell Precision 7560 Touchpad Replacement, Speaker: 步骤 4 中的图像 3,3
    • Loosen the eight captive screws that secure the fan assembly using a Phillips #0 screwdriver.
    • Lifting from the bottom, carefully remove the fan.
  5. Dell Precision 7560 Touchpad Replacement: 步骤 5 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 5 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 5 中的图像 3,3
    • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Remove the metal overlay.
    • Disconnect the wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card.
  6. Dell Precision 7560 Touchpad Replacement: 步骤 6 中的图像 1,2 Dell Precision 7560 Touchpad Replacement: 步骤 6 中的图像 2,2
    • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
    • Remove, carefully and completely, any wires running over the frame.
    • Lift the metal frame.
  7. Dell Precision 7560 Touchpad Replacement: 步骤 7 中的图像 1,2 Dell Precision 7560 Touchpad Replacement: 步骤 7 中的图像 2,2
    • Flip up the metal edge holding down the SD connection.
    • Gently pull to disconnect the metal connecting wire.
  8. Dell Precision 7560 Touchpad Replacement: 步骤 8 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 8 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 8 中的图像 3,3
    • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
    • Remove the metal cap.
    • Disconnect the wire bundle.
  9. Dell Precision 7560 Touchpad Replacement: 步骤 9 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 9 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 9 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
    • Carefully remove the speaker wire from the motherboard.
  10. Dell Precision 7560 Touchpad Replacement: 步骤 10 中的图像 1,2 Dell Precision 7560 Touchpad Replacement: 步骤 10 中的图像 2,2
    • Using both hands, carefully lift and remove the speaker.
  11. Dell Precision 7560 Touchpad Replacement, Touchpad: 步骤 11 中的图像 1,2 Dell Precision 7560 Touchpad Replacement, Touchpad: 步骤 11 中的图像 2,2
    • Gently remove and disconnect the connecting strip from the touchpad.
    • Remove the two 2 mm screws using a Phillips #0 screwdriver.
    • Remove the black tab from the bottom of the touchpad.
  12. Dell Precision 7560 Touchpad Replacement: 步骤 12 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 12 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 12 中的图像 3,3
    • Lift up the white connecting strip with your finger.
    • Using a Phillips #0 screwdriver, remove the two 2 mm screws.
    • Remove the metal bracket.
  13. Dell Precision 7560 Touchpad Replacement: 步骤 13 中的图像 1,2 Dell Precision 7560 Touchpad Replacement: 步骤 13 中的图像 2,2
    • Detach the blue and white connecting tab using an opening tool.
  14. Dell Precision 7560 Touchpad Replacement: 步骤 14 中的图像 1,3 Dell Precision 7560 Touchpad Replacement: 步骤 14 中的图像 2,3 Dell Precision 7560 Touchpad Replacement: 步骤 14 中的图像 3,3
    • Warm all sides of the touch pad using an iOpener to loosen the glue.
    • Lift the warmed up sides with a metal spudger.
  15. Dell Precision 7560 Touchpad Replacement: 步骤 15 中的图像 1,2 Dell Precision 7560 Touchpad Replacement: 步骤 15 中的图像 2,2
    • Use your fingers to take out the touchpad.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 64
总计 602
