跳转到主内容
Dell Latitude E6540 Battery Replacement
你所需要的
  1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: 步骤 1 中的图像 1,2 Dell Latitude E6540 Battery Replacement, Hibernate your laptop: 步骤 1 中的图像 2,2
    • It is possible to plug the laptop in to avoid hibernating the system.
    • Locate the Hibernate option in the Start menu. Let the system fully hibernate (or shut down) before removing the battery.
  2. Dell Latitude E6540 Battery Replacement, Unlock the battery: 步骤 2 中的图像 1,2 Dell Latitude E6540 Battery Replacement, Unlock the battery: 步骤 2 中的图像 2,2
    • Flip the laptop over and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Battery Replacement, Remove the old battery: 步骤 3 中的图像 1,3 Dell Latitude E6540 Battery Replacement, Remove the old battery: 步骤 3 中的图像 2,3 Dell Latitude E6540 Battery Replacement, Remove the old battery: 步骤 3 中的图像 3,3
    • The "extended runtime" battery on this model will stick out a few inches by design. This cannot be avoided.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Battery Replacement, Install the new battery: 步骤 4 中的图像 1,3 Dell Latitude E6540 Battery Replacement, Install the new battery: 步骤 4 中的图像 2,3 Dell Latitude E6540 Battery Replacement, Install the new battery: 步骤 4 中的图像 3,3
    • This step does not apply if this guide is being used as a prerequisite.
    • Align the battery with the tabs on the chassis. Drop the battery in place once lined up. If needed, use light pressure to seat it in the computer.
  5. Dell Latitude E6540 Battery Replacement, Plug your laptop in: 步骤 5 中的图像 1,1
    • Turn the computer on and plug the charger in.
终点
7等其他人完成本指南。
Nick
于11/10/09注册
88,911 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,541篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 44
总计 8,167
