跳转到主内容
Dell Inspiron E1505 Optical Drive Replacement
你所需要的
  1. Dell Inspiron E1505 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 1,3 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 2,3 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 3,3
    • Remove the back panel: Use the screwdriver to remove the screws on the back panel.
    • Lift the back panel off the laptop to expose the interior of the laptop.
    • Locate the hard drive.
  6. Dell Inspiron E1505 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the current optical drive.
    • Look at the model number and order the replacement if needed.
    • Insert the new optical drive in.
结论
Anthony Toscano
于10/20/16注册
323 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-7, Martin Fall 2016 UMass Dartmouth, Team 6-7, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G7
3 名成员
创作了4篇指南
2条评论
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
George A. - 回复
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
oldturkey03 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 725
