跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 700m RAM Replacement
你所需要的
  1. Dell Inspiron 700m RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, make sure the 700m is powered off.
    • Unplug the power cable.
    • Flip the 700m over and remove the battery.
    • Slide the battery release switch toward the center of the 700m, and then pull the battery free from the back.
  2. Dell Inspiron 700m RAM Replacement, Outer RAM Cover: 步骤 2 中的图像 1,1
    • Remove the two Phillips screws securing the RAM cover.
    • Remove the RAM cover and set it aside.
  3. Dell Inspiron 700m RAM Replacement, RAM Module #1: 步骤 3 中的图像 1,3 Dell Inspiron 700m RAM Replacement, RAM Module #1: 步骤 3 中的图像 2,3 Dell Inspiron 700m RAM Replacement, RAM Module #1: 步骤 3 中的图像 3,3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, touch only the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, slide it in place at about the same angle until it is snug, and then swing it downward until the two clips snap into place.
  4. Dell Inspiron 700m RAM Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 700m RAM Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 700m RAM Replacement: 步骤 4 中的图像 3,3
    • Flip the 700m over and swing the screen all the way open until it lays flat.
    • Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top edge of the keyboard. Remove the trim.
  5. Dell Inspiron 700m RAM Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Remove the two Phillips screws securing the keyboard.
  6. Dell Inspiron 700m RAM Replacement: 步骤 6 中的图像 1,1
    • Tilt the top of the keyboard up at an angle, and gently push the keyboard toward the back of the 700m, freeing the tabs along the bottom.
    • Do not push very hard, or you may damage the keyboard ribbon cable.
  7. Dell Inspiron 700m RAM Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 700m RAM Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 700m RAM Replacement: 步骤 7 中的图像 3,3
    • Tilt the bottom of the keyboard up at an angle.
    • Use the pointed end of a spudger to disconnect the keyboard ribbon cable by pushing open the clips on either side.
    • Remove the keyboard and set it aside.
  8. Dell Inspiron 700m RAM Replacement, Inner RAM Cover: 步骤 8 中的图像 1,2 Dell Inspiron 700m RAM Replacement, Inner RAM Cover: 步骤 8 中的图像 2,2
    • Remove the two Phillips screws securing the inner RAM cover.
    • Tilt the right side of the RAM cover up at an angle and pull it free.
  9. Dell Inspiron 700m RAM Replacement, RAM Module #2: 步骤 9 中的图像 1,2 Dell Inspiron 700m RAM Replacement, RAM Module #2: 步骤 9 中的图像 2,2
结论
4等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
449,324 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,138篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 3,794
