跳转到主内容
Dell Inspiron 3501 SSD Replacement
你所需要的
  1. Dell Inspiron 3501 SSD Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 Dell Inspiron 3501 SSD Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 SSD Replacement, Unclip the front corners: 步骤 2 中的图像 1,2 Dell Inspiron 3501 SSD Replacement, Unclip the front corners: 步骤 2 中的图像 2,2
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 SSD Replacement, Unclip the sides: 步骤 3 中的图像 1,2 Dell Inspiron 3501 SSD Replacement, Unclip the sides: 步骤 3 中的图像 2,2
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 SSD Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Dell Inspiron 3501 SSD Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Dell Inspiron 3501 SSD Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
  5. Dell Inspiron 3501 SSD Replacement, Disconnect the battery: 步骤 5 中的图像 1,2 Dell Inspiron 3501 SSD Replacement, Disconnect the battery: 步骤 5 中的图像 2,2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 SSD Replacement, Unfasten the SSD cover: 步骤 6 中的图像 1,2 Dell Inspiron 3501 SSD Replacement, Unfasten the SSD cover: 步骤 6 中的图像 2,2
    • Use your Phillips screwdriver to remove the 4 mm-long screw securing the silver SSD shield.
    • Use your Phillips screwdriver to loosen the captive screw.
  7. Dell Inspiron 3501 SSD Replacement, Remove the SSD cover: 步骤 7 中的图像 1,2 Dell Inspiron 3501 SSD Replacement, Remove the SSD cover: 步骤 7 中的图像 2,2
    • Lift the SSD cover straight off the SSD to remove it.
  8. Dell Inspiron 3501 SSD Replacement, Remove the SSD: 步骤 8 中的图像 1,3 Dell Inspiron 3501 SSD Replacement, Remove the SSD: 步骤 8 中的图像 2,3 Dell Inspiron 3501 SSD Replacement, Remove the SSD: 步骤 8 中的图像 3,3
    • Grip the edges of the SSD near the screw indent.
    • Pull the SSD straight out from its socket and remove it.
    • If it feels stuck, gently wiggle it side to side as you pull.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
3等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
95,856 声望
创作了466篇指南
1指南评论
Thank you very much
jAnitH PrAmoDYa - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 54
总计 2,117
