跳转到主内容
Dell Inspiron 3501 Back Cover Replacement
你所需要的
  1. Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: 步骤 2 中的图像 1,2 Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: 步骤 2 中的图像 2,2
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: 步骤 3 中的图像 1,2 Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: 步骤 3 中的图像 2,2
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
Clay Eickemeyer
于09/19/22注册
95,329 声望
创作了465篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 66
总计 2,131
