跳转到主内容
Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement
你所需要的
  1. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 2 中的图像 2,2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 3 中的图像 3,3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Detach the tab connecting the battery to the system board using your fingers or a pair of tweezers.
    • Peel off the adhesive tab holding the cable to the device.
  6. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 6 中的图像 1,1
    • Flip the device over. Press and hold the power button for a few seconds to discharge any leftover electrical current.
    • You may leave the screen open if further repair is needed, or close it if you are only replacing the battery.
  7. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: 步骤 7 中的图像 3,3
    • Dell's official service manual does not mention of the 5th screw located near the middle edge of the battery closer to the touchpad.
    • Flip the device back over.
    • Remove five 3 mm screws that are securing the battery using a Phillips #0 screwdriver.
    • Lift the battery upwards to remove it completely.
结论
2等其他人完成本指南。
Antonio Franco
于08/25/22注册
1,025 声望
创作了10篇指南
团队
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 的会员
GCC-CLASS-F22S1G3
4 名成员
创作了15篇指南
5条评论
Looks good , where I can get Battery Replacement from ?
ilan magen - 回复
Hello! You can look at newegg com, amazon.com or ebay.com. That's where you can get a bunch of great used parts!
Delia Padilla -
THANK YOU, THANK YOU, THANK YOU! I replaced the battery following your instructions. The only thing I did differently is that I couldn't get the plug out with the battery still screwed down, so I unscrewed the battery then unplugged it. After unplugging, then I held down the power key for a few seconds to discharge before plugging in the new battery and screwing it down. My computer will be like new now! Blessings to all of you at IFixIt!
I bought my new replacement battery from the store at IFixIt.com.
Brenda McCurdy Cable - 回复
You're welcome! I'm glad our project could help you!
Delia Padilla -
After I've ''discharged any leftover power" by holding the power button down. What do I do ? Do I leave it until the laptop turns off by itself ? Or do I hold down the power button to force shutdown ?
Kalafinwë - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 52
总计 934
