跳转到主内容
Dell Inspiron 17 N7010 BIOS Battery Replacement
你所需要的
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: 步骤 1 中的图像 1,1
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 步骤 2 中的图像 1,3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 步骤 2 中的图像 2,3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 步骤 2 中的图像 3,3
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: 步骤 3 中的图像 1,1
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: 步骤 4 中的图像 1,2 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: 步骤 4 中的图像 2,2
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: 步骤 5 中的图像 1,1
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
结论
14等其他人完成本指南。
Joseph Sctbunio
于09/23/17注册
7,416 声望
创作了42篇指南
7条评论
thanks for your help!!!
E P - 回复
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - 回复
Thanks for the instructions. Computer starts up great now.
jkleinjans - 回复
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 102
总计 18,145
