你所需要的
Remove the single Philips screw securing the disc drive.
Pull the disc drive out.
Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
Unscrew the two captive screws securing the RAM/HDD door to the base.
Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
Remove the three M2.5x5 screws from under where the hard drive was.
Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
Remove the keyboard cable from the motherboard connector.
Remove the palmrest cables from the motherboard connectors.
Remove the seven M2.5x5 screws securing the palmrest to the base.
Lift the palmrest.
Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
14等其他人完成本指南。
7条评论
I’m happy that my guide helped you!
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Thanks for the instructions. Computer starts up great now.
jkleinjans - 回复
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
