跳转到主内容
Dell Inspiron 15 5584 Battery Replacement
你所需要的
  1. Dell Inspiron 15 5584 Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15 5584 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15 5584 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Battery Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15 5584 Battery Replacement: 步骤 3 中的图像 2,2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15 5584 Battery Replacement: 步骤 4 中的图像 2,2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Dell Inspiron 15 5584 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Battery Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15 5584 Battery Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15 5584 Battery Replacement: 步骤 6 中的图像 3,3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
结论
另外一个人完成了本指南。
Sam Vorn
于03/29/22注册
977 声望
创作了9篇指南
团队
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S1G1
3 名成员
创作了10篇指南
2条评论
I used this guide for a Dell Inspiron 5579 and it was close enough. The 5579 is larger. There were 10 screws instead of 9, and the back corner screws were removable. For the battery there were only the 2 left screws to remove as the 2 right battery mounts were also case-mounting screws. Was easy peazy. Now just need to charge it! Thanks!
John Highet - 回复
Thanks for this guide! I discovered right away that I bought the battery for the 5548 accidentally and had to ship it back. I got the battery for the 5584, and by following this guide, I got it up and running within minutes.
One concern: the new battery has a closer port for the motherboard connector tab, which means the cable for that tab has to bend a bit. Hopefully I haven't introduced a problem with heat or anything.
Gianfranco Berardi - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 21
过去 30 天: 86
总计 3,501
