跳转到主内容
Dell Inspiron 15 5577 Gaming Battery Replacement
你所需要的
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15 5577 Gaming Battery Replacement: 步骤 3 中的图像 2,2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: 步骤 5 中的图像 1,1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
结论
另外一个人完成了本指南。
[deleted]
于10/31/19注册
346 声望
创作了2篇指南
一条评论
Thank you, you guys rock
Random User - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 52
总计 5,694
