跳转到主内容
Dell Inspiron 14 5100 Touch Pad Replacement
你所需要的
  1. Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 1,3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 2,3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 3,3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 2 中的图像 2,2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Touch Pad Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 14 5100 Touch Pad Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 4 中的图像 3,3
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: 步骤 5 中的图像 1,3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: 步骤 5 中的图像 2,3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: 步骤 5 中的图像 3,3
    • Disconnect the touchpad cable attached to the motherboard.
    • Be careful lifting the Flat Flex Cable (FFC) connector as it is quite fragile.
  6. Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 6 中的图像 2,2
    • Peel off the tapes securing the touchpad to the keyboard assembly.
  7. Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 7 中的图像 1,1
    • Remove the four screws securing the touchpad to the keyboard assembly using the Phillips #0 screwdriver.
  8. Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 8 中的图像 3,3
    • Remove the three screws securing the touchpad bracket to the keyboard assembly using the Phillips #0 screwdriver.
    • Lift the touchpad bracket.
  9. Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 14 5100 Touch Pad Replacement: 步骤 9 中的图像 2,2
    • Lif tthe touchpad and replace with the new touchpad.
    • Make sure to guide the touchpad cable along with the touchpad to avoid damaging the parts.
    • Lift the touchpad at an angle from under the touchpad bracket to avoid damaging the touchpad or the touchpad bracket.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,036
