跳转到主内容
Dell Inspiron 14 5100 Power Adapter Port Replacement
你所需要的
  1. Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 1,3 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 2,3 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 3,3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Power Adapter Port Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 14 5100 Power Adapter Port Replacement: 步骤 2 中的图像 2,2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: 步骤 3 中的图像 1,2 Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: 步骤 3 中的图像 2,2
    • Disconnect the power-adapter port cable from the motherboard.
  4. Dell Inspiron 14 5100 Power Adapter Port Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 14 5100 Power Adapter Port Replacement: 步骤 4 中的图像 2,2
    • Remove the two screws securing the power adapter port to the keyboard assembly using the Phillips #0 screwdriver.
  5. Dell Inspiron 14 5100 Power Adapter Port Replacement: 步骤 5 中的图像 1,1
    • Remove the power adapter port and remove it from the device.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 3,468
