跳转到主内容
Dell Inspiron 13-7347 Motherboard Replacement
你所需要的
  1. Dell Inspiron 13-7347 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Motherboard Replacement, Fan: 步骤 5 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement, Fan: 步骤 5 中的图像 2,2
    • You should be able to identify the fan.
    • This is the 2mm x 2mm JIS #00 screw.
    • This is the 2mm x 3mm JIS #00 screw.
  6. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the 2mm x 2mm JIS #00 screw.
    • Remove the 2mm x 3mm JIS #00 screw.
  7. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Detach the cable that connects the fan and the motherboard.
    • The cable is extremely fragile.
  8. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Detach the cord that connects the fan and the motherboard.
  9. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the fan.
  10. Dell Inspiron 13-7347 Motherboard Replacement, Hard Drive: 步骤 10 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement, Hard Drive: 步骤 10 中的图像 2,2
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
  11. Dell Inspiron 13-7347 Motherboard Replacement, Display Assembly: 步骤 11 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement, Display Assembly: 步骤 11 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement, Display Assembly: 步骤 11 中的图像 3,3
    • Using a Phillips #0 screwdriver, loosen the three 3.0 mm heat sink screws.
    • Remove the Heat Sink.
    • When reinstalling the heat sink, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
  12. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two 5.0 mm screws on the metal bracket.
    • Remove the metal bracket.
  13. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Loosen and reposition the display cable.
    • The display cable will not be removed. Do not attempt to remove the display cable.
  14. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 14 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 14 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove the 5.0mm screw on the left display hinge bracket.
    • Using a Phillips #0 screwdriver, remove the two 5.0mm screws on the right display hinge bracket.
    • Lift and remove the display assembly.
  15. Dell Inspiron 13-7347 Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement, Motherboard: 步骤 15 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement, Motherboard: 步骤 15 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove the 5.0 mm DC jack screw.
    • Unplug and remove the DC jack.
  16. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 16 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 16 中的图像 2,2
    在这个步骤中使用的工具:
    • Using your fingers or a pair of tweezers, unplug and loosen the display cable by pulling it straight out of its connector.
  17. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Using your fingers or a pair of tweezers, unplug the speaker cable by pulling it straight out of its connector.
  18. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 18 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Unplug and remove keyboard cable.
  19. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 19 中的图像 1,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 19 中的图像 2,3 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 19 中的图像 3,3
    • Using your fingers or a pair of tweezers, unplug the three motherboard cables by pulling them straight out of their connectors.
  20. Dell Inspiron 13-7347 Motherboard Replacement: 步骤 20 中的图像 1,2 Dell Inspiron 13-7347 Motherboard Replacement: 步骤 20 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove one 2.5mm motherboard screw.
    • Remove the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 523
