跳转到主内容
Dell Inspiron 13-5368 Audio Jack Replacement
你所需要的
  1. Dell Inspiron 13-5368 Audio Jack Replacement, 3.5 mm Audio Jack: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 9 6mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 2 中的图像 1,1
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 4 中的图像 1,1
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery.
  5. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips #0 screwdriver, unscrew the 4 heatsink screws.
    • Remove the heatsink assembly.
  6. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #0, unscrew two 3mm screws holding the fan in place and disconnect the cable connecting it to the motherboard. There is an adhesive tab holding the hard drive cable in place up against the fan; remove this as well.
  7. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 7 中的图像 3,3
    • Disconnect the following cables that connect to the motherboard: the Touchscreen, Display, and the speaker cable.
  8. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 8 中的图像 3,3
    • Disconnect the following cables that connect to the motherboard: hard drive cable and touchpad cable.
  9. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 9 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the three 2mm screws holding the motherboard in place. Once done, carefully lift the motherboard out.
  10. Dell Inspiron 13-5368 Audio Jack Replacement: 步骤 10 中的图像 1,1
    • Flip the motherboard over and, using a soldering iron, apply heat to the 7 solder points of the audio jack. Carefully pull the audio jack out from below.
    • For more tips on soldering, please visit the How to Solder and Desolder Connections guide.
结论
Ian Zahar
于11/10/18注册
208 声望
撰写一个指南
团队
IUPUI, Team S4-G4, Wilson Fall 2018 IUPUI, Team S4-G4, Wilson Fall 2018 的会员
IUPUI-WILSON-F18S4G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 1,894
