跳转到主内容
Dell Inspiron 13 7378 Heat Sink Replacement
你所需要的
  1. Dell Inspiron 13 7378 Heat Sink Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 3 中的图像 3,3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Heat Sink Replacement, Heat Sink: 步骤 4 中的图像 1,1
    • Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
  5. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 5 中的图像 2,2
    • Check to see if the fan will obstruct the removal process and if so, remove the fan first before removing the heat sink to prevent any damage.
    • In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
  6. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 6 中的图像 1,1
    • Before you install a new compatible cooling system, place a fresh coat of thermal paste in the center of where the previous cooling system used to be.
结论
Replace the back cover to complete the process.
3等其他人完成本指南。
Javier Perez
于02/08/22注册
277 声望
创作了2篇指南
团队
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G3
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 317
