跳转到主内容
Dell Inspiron 11-3162 Wireless WLAN Card Replacement
你所需要的
  1. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 4 中的图像 3,3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Battery: 步骤 5 中的图像 1,2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Battery: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Wireless WLAN Card: 步骤 7 中的图像 1,2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Wireless WLAN Card: 步骤 7 中的图像 2,2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: 步骤 9 中的图像 1,1
    • Pull out the WiFi Chip.
结论
4等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 791
