简介
You'd want to follow this guide if you've attempted to troubleshoot your device following our steps. The Palmrest unit is a combined keyboard and touchpad, which makes it easy for us to replace!
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
Use tweezers to pry and remove the center screw cover on the back cover.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
Gently grip and pull the speaker to remove it.
Now you've removed the Palmrest keyboard!
结论
2等其他人完成本指南。
