跳转到主内容
Dell Inspiron 11-3162 LCD Screen Replacement
你所需要的
  1. Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 LCD Screen Replacement, Battery: 步骤 5 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement, Battery: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: 步骤 7 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: 步骤 7 中的图像 2,2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 2,2
    • Remove the two screws that hold down the LCD hinges.
  11. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Pull the hinges back and remove the screen.
  12. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the hinge covers with your spudger tool.
  13. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Carefully remove the LCD Bezel with your regular black nylon spudger tool by bringing it all the way around the outer edges of your screen.
  14. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 14 中的图像 1,3 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 14 中的图像 2,3 Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 14 中的图像 3,3
    • Remove the four screws with a PH00 sized bit.
    • Flip the screen over.
  15. Dell Inspiron 11-3162 LCD Screen Replacement: 步骤 15 中的图像 1,1
    • Loosen the tape, and remove the LCD Cable.
    • Remove the screen.
结论
5等其他人完成本指南。
2条评论
Between steps 9 and 10, the motherboard is removed and no description photos are provided for this. I undid the cable on the right hinge and then removed the hinges and screen with the motherboard in place, but the pictures definitely show it removed. Otherwise a very easy to follow process.
Philip Blakemore - 回复
I agree with Philip’s comment re: the missing step between 9 and 10. I successfully followed these very clear instructions to repair my daughter’s Chromebook. Thank you!
Katrina Dalrymple - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,658
