跳转到主内容
加入维修社区 - 创建账户
Dell Chromebook 5190 WLAN Card Replacement
你所需要的
  1. Dell Chromebook 5190 WLAN Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
    询问修复机器人
    添加评论
  2. Dell Chromebook 5190 WLAN Card Replacement: 步骤 2 中的图像 1,3 Dell Chromebook 5190 WLAN Card Replacement: 步骤 2 中的图像 2,3 Dell Chromebook 5190 WLAN Card Replacement: 步骤 2 中的图像 3,3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
    询问修复机器人
    添加评论
  3. Dell Chromebook 5190 WLAN Card Replacement: 步骤 3 中的图像 1,2 Dell Chromebook 5190 WLAN Card Replacement: 步骤 3 中的图像 2,2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
    询问修复机器人
    添加评论
  4. Dell Chromebook 5190 WLAN Card Replacement: 步骤 4 中的图像 1,2 Dell Chromebook 5190 WLAN Card Replacement: 步骤 4 中的图像 2,2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
    询问修复机器人
    添加评论
  5. Dell Chromebook 5190 WLAN Card Replacement: 步骤 5 中的图像 1,2 Dell Chromebook 5190 WLAN Card Replacement: 步骤 5 中的图像 2,2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
    询问修复机器人
    添加评论
  6. Dell Chromebook 5190 WLAN Card Replacement: 步骤 6 中的图像 1,3 Dell Chromebook 5190 WLAN Card Replacement: 步骤 6 中的图像 2,3 Dell Chromebook 5190 WLAN Card Replacement: 步骤 6 中的图像 3,3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
    询问修复机器人
    添加评论
  7. Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: 步骤 7 中的图像 1,2 Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: 步骤 7 中的图像 2,2
    • Unscrew and remove the M2x3 screw.
    • Remove the metal bracket.
    询问修复机器人
    添加评论
  8. Dell Chromebook 5190 WLAN Card Replacement: 步骤 8 中的图像 1,1
    • Remove WLAN antennas.
    询问修复机器人
    添加评论
  9. Dell Chromebook 5190 WLAN Card Replacement: 步骤 9 中的图像 1,1
    • Slide the WLAN card away from the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Brian
于02/10/22注册
97 声望
撰写一个指南
团队
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022 的会员
GCC-PEE-S22S1G3
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 372
