跳转到主内容
DeWalt DC970 Motor Replacement
你所需要的
  1. DeWalt DC970 Motor Replacement, Battery: 步骤 1 中的图像 1,1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Motor Replacement: 步骤 2 中的图像 1,1
    • Remove battery from drill.
  3. DeWalt DC970 Motor Replacement, Drill Assembly: 步骤 3 中的图像 1,2 DeWalt DC970 Motor Replacement, Drill Assembly: 步骤 3 中的图像 2,2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Motor Replacement: 步骤 4 中的图像 1,1
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Motor Replacement, Motor: 步骤 5 中的图像 1,1
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
  6. DeWalt DC970 Motor Replacement: 步骤 6 中的图像 1,1
    • Slightly twist and pull motor away from the clutch.
  7. DeWalt DC970 Motor Replacement: 步骤 7 中的图像 1,1
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
结论
2等其他人完成本指南。
Jonathan Hamel
于03/10/16注册
633 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G2
3 名成员
创作了13篇指南
3条评论
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - 回复
Thanks for the heads up on the wires
Daniel Randall - 回复
Is there a fix to replace brushes?
pmac086 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 44
总计 6,531
