简介
When the grindstones wear out, the coffee becomes thin and stale. With this grinder, replacing the grindstones is a bit difficult. The complete grinding mechanism is more expensive than the grinding stones themselves, but it is quite easy to replace. This guide shows you how.
Also take a look at our wiki DeLonghi grinder jams.
你所需要的
The rear panel and side panels are attached with six phillips screws #2. Screw them out.
The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
Lift out the left side piece.
The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
Use a plastic opening tool to lever off the steam tap.
Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
Two Phillips screws PH2 hold the lid at the back. Turn it out.
Lift the lid upwards.
Pull the flat connectors of the two black cables that lead to the grinder from the main circuit board.
Work the steps in reverse order to reassemble your device.
由衷感谢以下译者:
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
