简介
It may be that the pump no longer works properly and builds up the pressure sufficiently. Often a valve ball inside the pump is defective, you may be able to replace it. But it may also be that the solenoid coil is no longer working. Pump Ulka EP5GW is not very expensive and replacement is quite simple.
你所需要的
Remove all attachments such as water tank, pulp drawer, brew group.
Turn the machine with the back facing you.
Remove five Torx T20 security screws.
Push the side panel back about 1.5 cm.
Lift off the panel.
The following compononents are exposed:
Heater
Expansion chamber
Gear drive
Steam valve
Work through the steps in reverse order to reassemble your device.
由衷感谢以下译者:
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
