跳转到主内容
Daughterboard Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Daughterboard Disconnection, Reposition the head strap: 步骤 1 中的图像 1,2 Daughterboard Disconnection, Reposition the head strap: 步骤 1 中的图像 2,2
    • Rotate the head strap forward as far as it will go.
  2. Daughterboard Disconnection, Unplug the All-In-One Cable: 步骤 2 中的图像 1,2 Daughterboard Disconnection, Unplug the All-In-One Cable: 步骤 2 中的图像 2,2
    • Unplug the All-In-One Cable from your headset.
  3. Daughterboard Disconnection, Remove the All-In-One Cable: 步骤 3 中的图像 1,3 Daughterboard Disconnection, Remove the All-In-One Cable: 步骤 3 中的图像 2,3 Daughterboard Disconnection, Remove the All-In-One Cable: 步骤 3 中的图像 3,3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. Daughterboard Disconnection, Remove the top strap: 步骤 4 中的图像 1,2 Daughterboard Disconnection, Remove the top strap: 步骤 4 中的图像 2,2
    • Separate the top strap from itself where the Velcro secures it.
  5. Daughterboard Disconnection: 步骤 5 中的图像 1,3 Daughterboard Disconnection: 步骤 5 中的图像 2,3 Daughterboard Disconnection: 步骤 5 中的图像 3,3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. Daughterboard Disconnection: 步骤 6 中的图像 1,3 Daughterboard Disconnection: 步骤 6 中的图像 2,3 Daughterboard Disconnection: 步骤 6 中的图像 3,3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. Daughterboard Disconnection, Remove the front side foam pads: 步骤 7 中的图像 1,3 Daughterboard Disconnection, Remove the front side foam pads: 步骤 7 中的图像 2,3 Daughterboard Disconnection, Remove the front side foam pads: 步骤 7 中的图像 3,3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. Daughterboard Disconnection, Remove the two rubber spacers: 步骤 8 中的图像 1,3 Daughterboard Disconnection, Remove the two rubber spacers: 步骤 8 中的图像 2,3 Daughterboard Disconnection, Remove the two rubber spacers: 步骤 8 中的图像 3,3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. Daughterboard Disconnection, Disconnect the speaker wires: 步骤 9 中的图像 1,3 Daughterboard Disconnection, Disconnect the speaker wires: 步骤 9 中的图像 2,3 Daughterboard Disconnection, Disconnect the speaker wires: 步骤 9 中的图像 3,3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. Daughterboard Disconnection, Remove the head strap: 步骤 10 中的图像 1,2 Daughterboard Disconnection, Remove the head strap: 步骤 10 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. Daughterboard Disconnection: 步骤 11 中的图像 1,1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. Daughterboard Disconnection: 步骤 12 中的图像 1,3 Daughterboard Disconnection: 步骤 12 中的图像 2,3 Daughterboard Disconnection: 步骤 12 中的图像 3,3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. Daughterboard Disconnection, Remove the outer shell: 步骤 13 中的图像 1,3 Daughterboard Disconnection, Remove the outer shell: 步骤 13 中的图像 2,3 Daughterboard Disconnection, Remove the outer shell: 步骤 13 中的图像 3,3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. Daughterboard Disconnection: 步骤 14 中的图像 1,2 Daughterboard Disconnection: 步骤 14 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. Daughterboard Disconnection: 步骤 15 中的图像 1,3 Daughterboard Disconnection: 步骤 15 中的图像 2,3 Daughterboard Disconnection: 步骤 15 中的图像 3,3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. Daughterboard Disconnection: 步骤 16 中的图像 1,3 Daughterboard Disconnection: 步骤 16 中的图像 2,3 Daughterboard Disconnection: 步骤 16 中的图像 3,3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. Daughterboard Disconnection: 步骤 17 中的图像 1,3 Daughterboard Disconnection: 步骤 17 中的图像 2,3 Daughterboard Disconnection: 步骤 17 中的图像 3,3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. Daughterboard Disconnection, Remove the face rest cushion: 步骤 18 中的图像 1,3 Daughterboard Disconnection, Remove the face rest cushion: 步骤 18 中的图像 2,3 Daughterboard Disconnection, Remove the face rest cushion: 步骤 18 中的图像 3,3
    • Use your fingers to gently peel the face rest cushion off of the headset.
  19. Daughterboard Disconnection, Disconnect the microphone: 步骤 19 中的图像 1,2 Daughterboard Disconnection, Disconnect the microphone: 步骤 19 中的图像 2,2
    • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
  20. Daughterboard Disconnection: 步骤 20 中的图像 1,2 Daughterboard Disconnection: 步骤 20 中的图像 2,2
    • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
  21. Daughterboard Disconnection, Disconnect the sensor array: 步骤 21 中的图像 1,2 Daughterboard Disconnection, Disconnect the sensor array: 步骤 21 中的图像 2,2
    • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
  22. Daughterboard Disconnection: 步骤 22 中的图像 1,2 Daughterboard Disconnection: 步骤 22 中的图像 2,2
    • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
  23. Daughterboard Disconnection: 步骤 23 中的图像 1,1
    • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
  24. Daughterboard Disconnection, Remove the sensor array screws: 步骤 24 中的图像 1,2 Daughterboard Disconnection, Remove the sensor array screws: 步骤 24 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
  25. Daughterboard Disconnection: 步骤 25 中的图像 1,3 Daughterboard Disconnection: 步骤 25 中的图像 2,3 Daughterboard Disconnection: 步骤 25 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
  26. Daughterboard Disconnection, Remove the sensor array: 步骤 26 中的图像 1,2 Daughterboard Disconnection, Remove the sensor array: 步骤 26 中的图像 2,2
    • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
    • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
  27. Daughterboard Disconnection, Remove the thermal pad: 步骤 27 中的图像 1,3 Daughterboard Disconnection, Remove the thermal pad: 步骤 27 中的图像 2,3 Daughterboard Disconnection, Remove the thermal pad: 步骤 27 中的图像 3,3
    • Use your fingers to peel up the thermal pad covering the daughterboard.
    • The thermal pad will likely remove the Kapton tape from the ZIF connectors on the daughterboard. Replace the Kapton tape if necessary.
    • Set aside the thermal pad. You'll reuse it during reassembly.
  28. Daughterboard Disconnection, Disconnect the lens assembly: 步骤 28 中的图像 1,3 Daughterboard Disconnection, Disconnect the lens assembly: 步骤 28 中的图像 2,3 Daughterboard Disconnection, Disconnect the lens assembly: 步骤 28 中的图像 3,3
    • Insert the flat end of a spudger under a corner of the lens assembly press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging nearby surface-mounted components.
    • Twist the spudger to lift the press connector up and disconnect it.
    • Repeat the same process to disconnect the other lens assembly press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  29. Daughterboard Disconnection, Disconnect the IPD sensor: 步骤 29 中的图像 1,2 Daughterboard Disconnection, Disconnect the IPD sensor: 步骤 29 中的图像 2,2
    • Use the point of a spudger to lift up the locking tab on the IPD sensor ZIF connector.
  30. Daughterboard Disconnection: 步骤 30 中的图像 1,2 Daughterboard Disconnection: 步骤 30 中的图像 2,2
    • Use tweezers, or your fingers, to pull the IPD sensor cable straight out of its socket.
  31. Daughterboard Disconnection, Disconnect the proximity sensor: 步骤 31 中的图像 1,2 Daughterboard Disconnection, Disconnect the proximity sensor: 步骤 31 中的图像 2,2
    • Use the point of a spudger to lift up the locking tab on the proximity sensor ZIF connector.
  32. Daughterboard Disconnection: 步骤 32 中的图像 1,2 Daughterboard Disconnection: 步骤 32 中的图像 2,2
    • Use tweezers, or your fingers, to pull the proximity sensor cable straight out of its socket.
结论
Alex Diaz-Kokaisl
于01/16/22注册
215,568 声望
创作了1,046篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,818篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 51
