跳转到主内容
DROCON Ninja Propeller Replacement
  1. DROCON Ninja Propeller Replacement, Battery: 步骤 1 中的图像 1,3 DROCON Ninja Propeller Replacement, Battery: 步骤 1 中的图像 2,3 DROCON Ninja Propeller Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Propeller Replacement, Propeller: 步骤 2 中的图像 1,2 DROCON Ninja Propeller Replacement, Propeller: 步骤 2 中的图像 2,2
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  3. DROCON Ninja Propeller Replacement: 步骤 3 中的图像 1,3 DROCON Ninja Propeller Replacement: 步骤 3 中的图像 2,3 DROCON Ninja Propeller Replacement: 步骤 3 中的图像 3,3
    • Take note of the letter printed on the bottom of the propeller. Make sure the replacement propeller has the same letter.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
结论
2等其他人完成本指南。
4条评论
can we buy an extra battery?
Orlay Gutierrez - 回复
can we buy an extra battery for the roconDC-014
hi i have the red & bleu drocon dc-014 & wold like to order the white drocon dc-014 white drone or white body cover
tank you! & happy new year!!!
claude demers - 回复
i both drocon dc-014 blue & red wold like by the white drocon dc-014 or uper casse
claude demers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 16
总计 1,679
