跳转到主内容
DR.J Professional HI-04 Lens Replacement
你所需要的
  1. DR.J Professional HI-04 Lens Replacement, Lens: 步骤 1 中的图像 1,3 DR.J Professional HI-04 Lens Replacement, Lens: 步骤 1 中的图像 2,3 DR.J Professional HI-04 Lens Replacement, Lens: 步骤 1 中的图像 3,3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: 步骤 2 中的图像 1,3 DR.J Professional HI-04 Lens Replacement: 步骤 2 中的图像 2,3 DR.J Professional HI-04 Lens Replacement: 步骤 2 中的图像 3,3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: 步骤 3 中的图像 1,2 DR.J Professional HI-04 Lens Replacement: 步骤 3 中的图像 2,2
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: 步骤 4 中的图像 1,2 DR.J Professional HI-04 Lens Replacement: 步骤 4 中的图像 2,2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: 步骤 5 中的图像 1,2 DR.J Professional HI-04 Lens Replacement: 步骤 5 中的图像 2,2
    • Unscrew the cover of the lens.
结论
Kory Lajoie
于11/01/23注册
127 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-5, Petersen Fall 2023 UMass Dartmouth, Team 1-5, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 46
总计 266
