跳转到主内容
DR.J Professional HI-04 Lamp Replacement
你所需要的
  1. DR.J Professional HI-04 Lamp Replacement, Motherboard: 步骤 1 中的图像 1,3 DR.J Professional HI-04 Lamp Replacement, Motherboard: 步骤 1 中的图像 2,3 DR.J Professional HI-04 Lamp Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lamp Replacement: 步骤 2 中的图像 1,3 DR.J Professional HI-04 Lamp Replacement: 步骤 2 中的图像 2,3 DR.J Professional HI-04 Lamp Replacement: 步骤 2 中的图像 3,3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Lamp Replacement: 步骤 3 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 3 中的图像 2,2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Lamp Replacement: 步骤 4 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Lamp Replacement: 步骤 5 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 5 中的图像 2,2
    • Squeeze the tab against the connector, and pull the connector straight out from the socket.
    • The cable will come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Lamp Replacement: 步骤 6 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 6 中的图像 2,2
    • Lift the motherboard from the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
    • Pull the cable from the connector.
  7. DR.J Professional HI-04 Lamp Replacement: 步骤 7 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 7 中的图像 2,2
    • Set down the motherboard safely.
  8. DR.J Professional HI-04 Lamp Replacement, Lamp: 步骤 8 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement, Lamp: 步骤 8 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  9. DR.J Professional HI-04 Lamp Replacement: 步骤 9 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 9 中的图像 2,2
    • Gently remove the black cover.
  10. DR.J Professional HI-04 Lamp Replacement: 步骤 10 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 10 中的图像 2,2
    • Remove the single piece of black tape.
    • Save the tape for reassembly.
  11. DR.J Professional HI-04 Lamp Replacement: 步骤 11 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove five 10.0 mm screws.
  12. DR.J Professional HI-04 Lamp Replacement: 步骤 12 中的图像 1,3 DR.J Professional HI-04 Lamp Replacement: 步骤 12 中的图像 2,3 DR.J Professional HI-04 Lamp Replacement: 步骤 12 中的图像 3,3
  13. DR.J Professional HI-04 Lamp Replacement: 步骤 13 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 13 中的图像 2,2
    • Remove the glass object with the orange ribbon cable connector.
    • Be careful removing object as it is fragile and can easily break.
  14. DR.J Professional HI-04 Lamp Replacement: 步骤 14 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 14 中的图像 2,2
    • Use a Phillips #0 to remove four 10.0 mm screws from the lamp.
  15. DR.J Professional HI-04 Lamp Replacement: 步骤 15 中的图像 1,2 DR.J Professional HI-04 Lamp Replacement: 步骤 15 中的图像 2,2
    • Gently slide the lamp out from the projector case.
结论
Baron Dutra
于11/01/23注册
825 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-5, Petersen Fall 2023 UMass Dartmouth, Team 1-5, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 73
总计 270
