跳转到主内容
DJI Phantom 3 Advanced LED Replacement
你所需要的
  1. DJI Phantom 3 Advanced LED Replacement, Battery: 步骤 1 中的图像 1,2 DJI Phantom 3 Advanced LED Replacement, Battery: 步骤 1 中的图像 2,2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced LED Replacement: 步骤 2 中的图像 1,2 DJI Phantom 3 Advanced LED Replacement: 步骤 2 中的图像 2,2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced LED Replacement, Cover: 步骤 3 中的图像 1,1
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced LED Replacement: 步骤 4 中的图像 1,1
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced LED Replacement: 步骤 5 中的图像 1,2 DJI Phantom 3 Advanced LED Replacement: 步骤 5 中的图像 2,2
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced LED Replacement: 步骤 6 中的图像 1,2 DJI Phantom 3 Advanced LED Replacement: 步骤 6 中的图像 2,2
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced LED Replacement: 步骤 7 中的图像 1,3 DJI Phantom 3 Advanced LED Replacement: 步骤 7 中的图像 2,3 DJI Phantom 3 Advanced LED Replacement: 步骤 7 中的图像 3,3
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced LED Replacement: 步骤 8 中的图像 1,3 DJI Phantom 3 Advanced LED Replacement: 步骤 8 中的图像 2,3 DJI Phantom 3 Advanced LED Replacement: 步骤 8 中的图像 3,3
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
  9. DJI Phantom 3 Advanced LED Replacement, LED: 步骤 9 中的图像 1,2 DJI Phantom 3 Advanced LED Replacement, LED: 步骤 9 中的图像 2,2
    • Follow the red,yellow and black wires from the LED to where they connect on the control board.
    • Scrape off the glue with a plastic opening tool. Use a metal opening tool if needed.
    • The LED wires are smaller than the motor wires.
  10. DJI Phantom 3 Advanced LED Replacement: 步骤 10 中的图像 1,1
    • Desolder the red, yellow and black wires that connect the LED to the control board. Check out the link below for more information on desoldering. Desoldering Information
  11. DJI Phantom 3 Advanced LED Replacement: 步骤 11 中的图像 1,2 DJI Phantom 3 Advanced LED Replacement: 步骤 11 中的图像 2,2
    • Use a plastic opening tool and wedge it under the LED.
    • Press down on the plastic opening tool and remove the LED.
结论
3等其他人完成本指南。
Tate Morell
于10/06/16注册
782 声望
创作了2篇指南
团队
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 21
总计 2,492
