你所需要的
Remove power cord, network cable, etc.
Remove paper tray and rear paper guide.
Slide the cover of the expansion slot backwards and open.
Unhook the flap from the lower hinge.
Loosen and remove front screws (1x top, 1x bottom) and rear (1x top, 1x bottom) with Phillips screwdriver.
Carefully loosen the front and rear housing parts with a light pull from the left.
Remove the left housing by carefully loosening the 3 clamps on the floor.
Follow the steps in reverse order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
