跳转到主内容
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
你所需要的
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 步骤 3 中的图像 1,1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 步骤 4 中的图像 1,1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 步骤 5 中的图像 1,1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 步骤 6 中的图像 1,1
    • Fit the wires back into the motor base and place the new power cord in the slot.
结论
By the end of this guide< you will have successfully replaced the power cord to your device.
另外一个人完成了本指南。
Reagan Burns
于04/02/15注册
119 声望
撰写一个指南
团队
Cal Poly, Team 24-1, Lancaster Spring 2015 Cal Poly, Team 24-1, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G1
2 名成员
创作了1篇指南
4条评论
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - 回复
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - 回复
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 1,615
