跳转到主内容
Cuisinart DFP-14BCN Safety Switch Replacement
你所需要的
  1. Cuisinart DFP-14BCN Safety Switch Replacement, Bowl: 步骤 1 中的图像 1,3 Cuisinart DFP-14BCN Safety Switch Replacement, Bowl: 步骤 1 中的图像 2,3 Cuisinart DFP-14BCN Safety Switch Replacement, Bowl: 步骤 1 中的图像 3,3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 3 中的图像 1,3 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 3 中的图像 2,3 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 3 中的图像 3,3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 4 中的图像 1,1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 5 中的图像 1,3 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 5 中的图像 2,3 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 5 中的图像 3,3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Safety Switch Replacement, Back Casing: 步骤 6 中的图像 1,2 Cuisinart DFP-14BCN Safety Switch Replacement, Back Casing: 步骤 6 中的图像 2,2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 7 中的图像 1,2 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 7 中的图像 2,2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 8 中的图像 1,3 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 8 中的图像 2,3 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 8 中的图像 3,3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 9 中的图像 1,2 Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 9 中的图像 2,2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Safety Switch Replacement, Safety Switch: 步骤 10 中的图像 1,3 Cuisinart DFP-14BCN Safety Switch Replacement, Safety Switch: 步骤 10 中的图像 2,3 Cuisinart DFP-14BCN Safety Switch Replacement, Safety Switch: 步骤 10 中的图像 3,3
    • Orient the device so that the power cord is facing you.
    • Remove the two 10.0mm screws that hold down the safety switch with a Phillips #2 screwdriver.
    • Pull up on the safety switch with your hands to lift it out of the casing.
  11. Cuisinart DFP-14BCN Safety Switch Replacement: 步骤 11 中的图像 1,1
    • Slide the plastic covering off of the brown wire connection to the safety switch by pulling gently.
    • Use a soldering iron to remove the solder from the safety switch for the white, brown and orange wires.
    • Follow this soldering guide for help with desoldering.
    • Remove the safety switch once all of the wires are desoldered.
    • For reassembly, you will need to solder the white, brown, and orange wire to the new connections.
结论
另外一个人完成了本指南。
Maddie McCool
于10/06/16注册
144 声望
创作了2篇指南
团队
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G3
3 名成员
创作了7篇指南
4条评论
Clear, precise instructions and great pics. This isn’t a difficult fix at all though, I would say it’s about a 4. The only reason I say that, is when people see a DIY labeled difficult, they tend to think it’s over their head, when many times it isn’t. One thing I would have like to see is what each of those wires do, because knowing that would ensure I don’t attach the wrong wire to the wrong part of the switch; or, like what I did, is drop the safety switch, and have all the little pieces come out of the plastic container.
AJ Woods - 回复
Where to buy replacement safety switch.
Mohammad Abidi - 回复
What is the white wire for on the safety switch. It seems the safety switch connects the brown and orange wire when activated, but sends the power to the white wire when not activated by installing the top that pushes the white pin down to turn on the switch. So when plugged in, the white wire is hot, like with power, and when the top is turned to lock on, the white wire is deactivated.????????
Mac
MacWain Phillips - 回复
My 2014 Cuisinart food processor (model FP-12MR) recently stopped spinning. The safety switch was not broken.
At any rate, I fixed it by depressing the safety switch on the front of the base unit and then jamming a toothpick in between the top of the depressed safety switch and the safety switch slot. Then I just broke off the toothpick that was left sticking out. This had the effect of permanently pinning the safety switch in the ON position.
NOTE: there is no disassembly required. The safety switch that I'm talking about is located on the base of the machine. It is on the front and is one of the recessed lock downs that locks the bowl in place when you rotate the bowl (counter clockwise). If you look into that recessed lock down you will see the switch. The way it is supposed to work is, when the bowl is locked in place and the lid is fastened down a small tab comes out of the base of the handle bowl handle and pushes the safety switch in.
John - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 35
总计 8,043
