跳转到主内容
CrystalView NB4-35788 Battery Replacement
你所需要的
  1. CrystalView NB4-35788 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Battery Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery using a plastic spudger.
    • Do not use a metal spudger, as this can damage the device.
  5. CrystalView NB4-35788 Battery Replacement: 步骤 5 中的图像 1,2 CrystalView NB4-35788 Battery Replacement: 步骤 5 中的图像 2,2
    • Peel back the yellow film on the old battery to expose the red and black wires
    • De-solder these wires to disconnect the old battery
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
结论
Courtney Clark
于01/12/17注册
218 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 310
