跳转到主内容
CrystalView NB4-35788 Auxiliary Speakers Replacement
你所需要的
  1. CrystalView NB4-35788 Auxiliary Speakers Replacement, Auxiliary Speakers: 步骤 1 中的图像 1,1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Auxiliary Speakers Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Auxiliary Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Auxiliary Speakers Replacement: 步骤 4 中的图像 1,1
    • Two speakers can be found on the device, one in the lower-right corner and one in the lower left-corner.
  5. CrystalView NB4-35788 Auxiliary Speakers Replacement: 步骤 5 中的图像 1,1
    • Gently pull up on the speaker to remove it. Repeat this for the other speaker.
  6. CrystalView NB4-35788 Auxiliary Speakers Replacement: 步骤 6 中的图像 1,2 CrystalView NB4-35788 Auxiliary Speakers Replacement: 步骤 6 中的图像 2,2
    • De-solder the red and black wires to disconnect the old speaker.
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
结论
Alex Stokes
于01/12/17注册
101 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 148
