跳转到主内容
Crosley CR42 Band Replacement
你所需要的
  1. Crosley CR42  Band Replacement, Band: 步骤 1 中的图像 1,1
    • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • If you believe the band may be broken or out of place, start by unplugging the record player.
  2. Crosley CR42  Band Replacement: 步骤 2 中的图像 1,2 Crosley CR42  Band Replacement: 步骤 2 中的图像 2,2
    • Make sure the needle is in its resting position off to the side.
    • Gently remove the turntable from the device by lifting it directly upward.
  3. Crosley CR42  Band Replacement: 步骤 3 中的图像 1,1
    • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Inspect your band for any tears, rips, or obvious signs of stretching.
  4. Crosley CR42  Band Replacement: 步骤 4 中的图像 1,1
    • Flip the turntable over.
    • Locate the notch on the back side of the turntable.
    • The notch will be on the outside edge of the turntable.
  5. Crosley CR42  Band Replacement: 步骤 5 中的图像 1,2 Crosley CR42  Band Replacement: 步骤 5 中的图像 2,2
    • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
    • Loop the band around the notch, the band should be taut.
  6. Crosley CR42  Band Replacement: 步骤 6 中的图像 1,2 Crosley CR42  Band Replacement: 步骤 6 中的图像 2,2
    • Place the turntable back onto the device.
    • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
  7. Crosley CR42  Band Replacement: 步骤 7 中的图像 1,1
    • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • Job well done!
终点
Roberto Rosila
于01/26/14注册
319 声望
创作了3篇指南
团队
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G38
4 名成员
创作了5篇指南
一条评论
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 27
总计 4,906
