跳转到主内容
Creative Zen V Plus Charging Port Replacement
你所需要的
  1. Creative Zen V Plus Charging Port Replacement, Prerequisite Only: 步骤 1 中的图像 1,1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Charging Port Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Charging Port Replacement: 步骤 3 中的图像 1,1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Charging Port Replacement: 步骤 4 中的图像 1,2 Creative Zen V Plus Charging Port Replacement: 步骤 4 中的图像 2,2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Charging Port Replacement: 步骤 5 中的图像 1,1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Charging Port Replacement: 步骤 6 中的图像 1,3 Creative Zen V Plus Charging Port Replacement: 步骤 6 中的图像 2,3 Creative Zen V Plus Charging Port Replacement: 步骤 6 中的图像 3,3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Charging Port Replacement, Charging Port: 步骤 7 中的图像 1,1
    • Locate the charging port on the logic board. Around the base of the rectangular port you will find the circles of metal that were used to solder the port to the board. De-solder these circles and remove the port.
    • Learn how to solder and desolder components with this guide!
结论
另外一个人完成了本指南。
Joshua Meines
于10/19/16注册
316 声望
创作了3篇指南
团队
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 304
