跳转到主内容
Creative Nomad Jukebox Zen Battery Replacement
你所需要的
  1. Creative Nomad Jukebox Zen Battery Replacement, Battery: 步骤 1 中的图像 1,3 Creative Nomad Jukebox Zen Battery Replacement, Battery: 步骤 1 中的图像 2,3 Creative Nomad Jukebox Zen Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Battery Replacement: 步骤 2 中的图像 1,2 Creative Nomad Jukebox Zen Battery Replacement: 步骤 2 中的图像 2,2
    • Use plastic opening tool to open top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Battery Replacement: 步骤 3 中的图像 1,1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover.
  4. Creative Nomad Jukebox Zen Battery Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to unclip the metal bracket holding the battery down.
    • When sticker is torn warranty is void.
  5. Creative Nomad Jukebox Zen Battery Replacement: 步骤 5 中的图像 1,2 Creative Nomad Jukebox Zen Battery Replacement: 步骤 5 中的图像 2,2
    • Desolder both red and black wires coming from battery.
    • 如何焊接和拆焊 Use soldering gun with care as it becomes extremely hot and can cause burns.
    • Make sure to solder the black and red wires back into the same locations.
结论
Eli Richter
于03/08/17注册
301 声望
创作了3篇指南
团队
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S4G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 1,213
