跳转到主内容
Creative Nomad Jukebox Zen Auxiliary Jack Input placement
你所需要的
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: 步骤 1 中的图像 1,3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: 步骤 1 中的图像 2,3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: 步骤 1 中的图像 3,3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 步骤 2 中的图像 1,3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 步骤 2 中的图像 2,3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: 步骤 3 中的图像 1,1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: 步骤 4 中的图像 1,1
    • Using a soldering iron, melt the solder in order to free the auxiliary jack.
    • 如何焊接和拆焊 Use soldering gun with care as it becomes extremely hot and can cause burns
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 步骤 5 中的图像 1,1
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 步骤 6 中的图像 1,1
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
结论
Bradley McHugh
于03/10/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S4G5
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 763
