跳转到主内容
加入维修社区 - 创建账户
Core Assembly Removal
你所需要的
  1. Core Assembly Removal, Power down your watch: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    询问修复机器人
    添加评论
  2. Core Assembly Removal, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
    添加评论
  3. Core Assembly Removal, Pry open the back cover: 步骤 3 中的图像 1,2 Core Assembly Removal, Pry open the back cover: 步骤 3 中的图像 2,2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
    添加评论
  4. Core Assembly Removal, Disconnect the sensor flex cable: 步骤 4 中的图像 1,2 Core Assembly Removal, Disconnect the sensor flex cable: 步骤 4 中的图像 2,2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    询问修复机器人
    添加评论
  5. Core Assembly Removal, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
    询问修复机器人
    添加评论
  6. Core Assembly Removal, Disconnect the hall sensor flex cable: 步骤 6 中的图像 1,2 Core Assembly Removal, Disconnect the hall sensor flex cable: 步骤 6 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
    询问修复机器人
    添加评论
  7. Core Assembly Removal, Disconnect the display flex cable: 步骤 7 中的图像 1,2 Core Assembly Removal, Disconnect the display flex cable: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the display flex cable.
    询问修复机器人
    添加评论
  8. Core Assembly Removal, Disconnect the side buttons: 步骤 8 中的图像 1,2 Core Assembly Removal, Disconnect the side buttons: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the crown button flex cable.
    询问修复机器人
    添加评论
  9. Core Assembly Removal, Unscrew the motherboard: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
    添加评论
  10. Core Assembly Removal, Remove the motherboard: 步骤 10 中的图像 1,3 Core Assembly Removal, Remove the motherboard: 步骤 10 中的图像 2,3 Core Assembly Removal, Remove the motherboard: 步骤 10 中的图像 3,3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
    询问修复机器人
    添加评论
  11. Core Assembly Removal, Lift the core assembly: 步骤 11 中的图像 1,3 Core Assembly Removal, Lift the core assembly: 步骤 11 中的图像 2,3 Core Assembly Removal, Lift the core assembly: 步骤 11 中的图像 3,3
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    询问修复机器人
    添加评论
  12. Core Assembly Removal, Release the core assembly: 步骤 12 中的图像 1,2 Core Assembly Removal, Release the core assembly: 步骤 12 中的图像 2,2
    • Thread the display flex cable through the opening in the core assembly.
    询问修复机器人
    添加评论
  13. Core Assembly Removal, Remove the core assembly: 步骤 13 中的图像 1,1
    • Remove the core assembly.
    询问修复机器人
    添加评论
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
取消:我没有完成这个指南。
2等其他人完成本指南。
Adriana Zwink
于12/18/19注册
67,169 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了25,947篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 46
总计 1,503
